We discovered yesterday (Christmas Eve) that the lower oven of our AEG built-under double oven wouldn't come on.
I could find out what heating element it has and replace that (I did this with the oven element in my daughter's free-standing cooker last year and it cost me less than a tenner to fix - dit I digress ...) however the fan in the upper oven conked out years ago and the light hasn't worked for ages either, so the CFO has decided we'll have a new oven.
The existing oven is on its own circuit from the CU, protedted by a 32A MCB. There is a double-pole 'cooker switch' in the kitchen.
I'm happy enough (and competent enough) to remove the old oven and re-wire the new and I'm also happy that the new oven is a lower power rating than the old, so the circuit will be fine.
Saying that I can re-wire the new oven onto the existing circuit with no alterations required, would I need to have an electrician certify the work and issue a 'Minor Works Certificate' or is it okay to undertake this work without one?
If we went with the second option and subsequently sold the house, we could simply state that the wiring was 'not up to current standards' or issue an indemnity certificate?
If we need to get an electrician to certify the job, we might as well get them to install the oven in the first place - yes? Any idea of an installation cost - £50??
Thanks folks and Merry Christmas,
XRD
XRD
