Hello,
I need to replace the wire from the sky satellite to the receiver. Only the run which comes from the dish to just inside the house will be replaced. I intend to use a connector to connect the two wires together. The cable inside the house is fine and will be too much work to replace it etc.
I have been reading a bit about these coaxial cables and found the following
www.screwfix.com
www.toolstation.com
From the spec all three seem to be similar. Solid 1mm copper core foam insulated and copper shielding with copper braiding.
The length of cable which I need is less than 10 meters.
Would anyone of these do the job? I understand there is the webro wf100 cable. I looked at the spec, they all seem to be identical if not similar. I am on a budget
Thank you.
Time GT100 White 1-Core Round Coaxial Cable 25m Drum - Screwfix
Order online at Screwfix.com. FREE next day delivery available, free collection in 1 minute.
Doncaster Cables Coaxial Satellite Cable (CT100) White 25m Drum | Toolstation
• 75 ohm • Low loss
www.toolstation.com
Thank you.
