- Joined
- 11 Apr 2022
- Messages
- 998
- Reaction score
- 218
- Country
My suggestion is a compromise to having nearly every room in a zone of its own.
In your first example I have a similar situation. I have 2 lounges joined by double doors which are open during the day but closed after about 19:00. The rooms have 3 radiators in total with the main lounge having 2 rads controlled by Wiser TRV's and a Wiser room stat.
Side question: if you don't use Opentherm and instead just have an on/off setup on the boiler, will it always run at 24.2kW?
So with that in mind I guess you should still just heat some rooms but maybe 3 or 4 radiators at a time rather than one at a time.
There is another side to this where having one room cold next to a room you are trying to heat could result in using more energy than just heating both rooms. It would be awesome if the system could automatically run a bunch of tests to be able to suggest changes like this
Regarding the flow rate temperature and hot water temperature, what happens with that when you connect Opentherm? I read somewhere that the knobs on the boiler itself which control these temperatures effectively become redundant once you connect Opentherm. Is that true? If so, do you then have control on that through the wiser app?
I just mean, on a combi boiler, you can select the hot water temperature and flow rate temperature with the two knobs on the front. But I thought one of the things Opentherm did was automatically adjust the flow rate temperature to more efficiently heat the radiators - but sounds like that's not true and instead it's just the modulation which is different. So sounds like the knobs still work as normal.
What's the deal with weather compensation?
But I guess wiser tells the boiler to switch heating on via opentherm and then it can use the temperature sensor to determine how intensely to hear the room etc?
Do I need an extra heating channel to use UFH with Wiser?
There is no requirement to have an extra channel on the Wiser Hub to support UFH.
The UFH control strip has a boiler output which can be wired to the boiler to ensure it fires when a UFH channel needs hot water, you can also on commissioning tell the Hub to activate either Channel 1 or 3 (hub type depending) when the UFH requires the boiler to fire.
