A few weeks back changed my Honeywell CM67z to a EvoHome.. I have had many teething problems but am starting to get used to the Nuances of the system.
I have 2xMotorized Vales in my Central heating, but they are wired in parallel.
I have a single BDR91 which opens both valves at the same time and all works nicely.
Last weekend I decided to integrate my Hot Water system into the Evohome and it was pretty straight forwards.. I replaced my 1 channel timer with the BDR91 and installed the Themocouple into the Dry Pocket on my tank and soon got it all bound up.
But then it came to the test and when I triggered the hot water, BOTH BDR91s activated starting opening the central heating and Hot water valves.
To cut a long story short, I believed I found the root of the issue and had the BDR91s "double bound" so I cleared it all out and started again... And I thought I had it working.
But because my tank was hot, I had very little chance to see it in operation, until today when my other 1/2 had a bath, using up much of the water.. Now the tank was down to 12 degrees, I had a good chance to play.
And I found it wasn't fixed.. And I am still getting CH and HW when I only call for HW.
I put all of the heating zones down to 5 degrees so there was no HW demand.. And turned on the heating, and both CH and HW BDR91s activate.. And when I look at "System Info" on the Evohome I can see that I have 100% against "APPLIANCE" and "HOT WATER STORAGE".. So the relays are actually doing what they are told and its the Evohome which is making the demand.
I ahve tried everything.. I have changed every option and re-bound the BDR91s more time that I can remember and the behaviour is constant.. if I create 0% demand for CH.. And then create demand for HW, both the CH and HW calls for heat.. And I am now starting to think I misunderstand how this all works and perhaps this is normal?
I can't see how, as before I had 2 independent "relays" controlling Water and CH.. So I don't know why the Evohome would combine them.. But perhaps there is a reason.
My fingers are crossed the someone can help me as I have run out of ideas and am currently thinking of putting my old timer back.
