Good screw set and bit
11 Dec 2012
I have a selection of screws which were bought quite some time ago which were cheap. They come in their own box with compartments in it.
I am sick of them to be honest. They are naff. In all ways!
I am after a good set of screws that are good for wood and general applications. Plus, a good bit for them.
The screws i use, whatever bit i use, it jumps out, or mauls the screw heads. No good grip.
Please advise. Thanks
I'm not necessarily recommending this set, due to the price!
But when I've tried them in smaller packs, they are a decent screw and I like the TX head...
I'm sure others will be along shortly with their reommendations :)
Forge fast or spectre for me, usually from toolstation, spectre are my preferred choice especially if restocking the full tray.
I also use milwaukee pz2 bits as they were on offer in toolstation at one point.
are you using an impact driver , do you have control over the speed
Mine has 3 settings and i have found , i use setting 1 or 2 - otherwise i get the same issue
But A DIYer , so have time to play around
If the box and compartments is good, then just buy the screws you need for now and store them in the organiser. Just buy some decent bits, usually in a small box, or the ones on offer like DeWalt et al.
No, just my combi drill.
As for technique questioned above, been DIY for decades (almost 60 years old now).
I too only have a combi drill for screwing stuff, I've managed all these years without an impact driver but a cheap screw won't cut through the wood like a decent screw so needs more torque, combine that with an under-powered driver and it's a recipe for disaster.
Bought one of these packs a year or so ago
Used for all sorts of things. Mostly using my DIY grade (Einhell) impact and PZ2 from my Bahco bit set.
Worth spending a bit on a branded bit set
