That just recreates the exact same situation slightly lower down.
I was hoping to space the water/crap away from the wall enough that it would just fall to the ground then (and not make contact with the wall on the way down) - if possible
What is the dimension of the overhang?
The U channel, fixed upside down under the slab lip, will cause the water to run down the front face of the channel and drip away from the wall, (unless the wind is in the wrong direction). The dirty water running between the slabs needs to be prevented, which means re-grouting with a waterproof grout after having removed the current stuff. Or you could clean out the current grout/sealer and re-do with a clear sealant that sets like rubber and is flexible to allow for expansion/contraction in the changing weather.
I used a clear/opaque silicone sealant around a washbasin over 5 years ago. It's had kids swinging from it, adults leaning on it etc and it is still stuck firmly to the wall. I think it may have been from Everbuild. Was definitely suitable for sanitary ware and the washbasin is mounted on a bare-brick wall. (Brick feature meaning it hasn't been plastered).
Will do. Thanks again.You will need to prop the channel in place for a few hours while the sealant sets. Just a couple of timber of the right length to slot in place overnight. Where you 'glue' it to the underside of the slab, run a thin bead along the out edge of the join so the water runs straight down and doesn't sit in a little hollow.
