I am going to do a three point turn and get out of this dead end,
If you click the 3 dots to the right of the Picture icon you can see a button likeWell it looks like I've got there but it seems one has to remember a fair bit while typing.
</> - if you click this you get a popup panel that is monospaced already so you can more easily visually design your text art, and it will insert your efforts together with the tags
One of consequent pains in this forum is that, since it doesn't have an 'indent' facility, most attempts to indent anything get frustrated by the forum software!
| How | ||||||||
| About | ||||||||
| Using | ||||||||
| A | ||||||||
| Table | ||||||||
| John? | ||||||||
If you click the 3 dots to the right of the Picture icon you can see a button like</>- if you click this you get a popup panel that is monospaced already so you can more easily visually design your text art, and it will insert your efforts together with the tags
Note that I post from a phone; the desk top view may differ slightly? But I'd expect the button to be the same icon
A A A
B X B B X B B X B
And what I see in edit mode:View attachment 300100
How it appeared on screen
Whatever appears below here is the result
[CODE] A A A B X B B X B B X B[/CODE]
V
I R
V
I R
O A O
S x H C x H T x A
It looks as if you are typing out the "code"s? - these are inserted automatically (when you use the </> option) - so don't have to be typed again.Am I doing something Wrong?
No, just clicked on the </> for this:Code:O A O S x H C x H T x A
Third attempt 3
Third attempt 3
Somehow, your [CODE] was inserted into an [ICODE] - Inline Programming Code Display.Got messy, deleted
Apparently there isOne of consequent pains in this forum is that, since it doesn't have an 'indent' facility,
Yes, I have occasionally used that 'workaround', but it's a pain. The previous version of the forum software simply has an 'indent' option, which seems an obvious thing to have!
How About Using A Table John?
