Veritas R8 alarm two tone beep fault
It is in the manual, i would use the engineers mode, but 41-47 are the basic event logs and pressing omit whilst in each will provide additional information.
Are you sure you haven’t turned chime on another zone or you have a faulty contact making it chime ? Turn off chime and see if you still get the noise
Not turned chime on.
I have a contact on the back door but the system is unset? It's as if the panel is resetting itself
Chime works on unset ….
Press the musical note …a chime noise says it’s on
A error noise says it’s off
Depends on what chime was programmed on originally…..let’s just see if it does it now ….everything is a guess unless your there yourself
