In short, a 13yr old megaflow (CL210HE) failed a while ago, as it appeared the baffles were breaking down. Megaflow accepted a fault and supplied a new replacement (inc all the fitting kit and MV). So I guess i'm one of the lucky ones...
But i've lost confidence in the product, I felt I was buying the best at the time but it seemed to always have an issue because it needed recharging ever 6-8wks. Maybe it had a problem since new and I never realised?
I've had a couple of plumbers around and i'm not sure which way to go, one plumber says they are sh*t, another says his own has been faultless for over ten years and i've had the two following suggestions:
1. Fit the replacement megaflow (all the pipework is in the correct place, I have the tank and everything I need here)
2. Fit something like a RM Stelflow 250l (will need to adjust more of the pipework, and make room for the external expansion vessel)
Obviously the advantage of fitting the warranty replacement is I have the product, and it's like for like so minimal work/cost. The disadvantage of the Stelflow is the cost to purchase and making space for the external expansion vessel. I know I can slightly off-set the purchase cost with the sale of the megaflow.
So should I stick or twist?
