Stand on some bricks?The trouble now is that I have reached my limit off the ground. I can no longer climb ladders, so not sure how I can add further courses.
You can make a decent underground repair and fill the box with magic gel, but for me, I would want it reinstating to what it was before they came along, IE an unbroken run of cable.
Let your mortar go off before you point upStarted adding bricks to these pillars.
Mrs S said she would come and fix the shed at the same time. So I started doing the brickwork.
"Love....can you pass me the secateurs?"
Few minutes later....
"Can you get me the spade?"
Bad light stopped play and I gave up at 22:00.
Mrs S: "Oh, you didn't get much done, did you?"
Now, bear in mind this is the second time ever I have laid any bricks. It won't win any competitions, but hopefully it will be strong and last a few more years.
Before the road is tarmacced and the heavy iron road cover is fitted, it was my last chance for a final, final check on the works so I dropped my boys off at the poolDrain check. All concreted now to a depth of about 4” from road level. Tarmac to be done tomorrow. As an experiment, I flushed a load of tissue down our upstairs toilet and it took 55 seconds to get to the main sewer in the street. That’ll do for me.![]()
You know, I thought about that, but all the brickies I have seen on site have done it all in one go, albeit going back over when it's firmed up a bit to tidy it up.Let your mortar go off before you point up
Get yourself some of the Ibuprofen with Lysine. The lysine makes it work faster.waiting for some ibuprofen to kick in
