Condensation on new basement walls
2 Sep 2015
Semi basement - 50% in ground, has 3 small 1m2 windows at ground level.
Tanking slurry applied to walls. No leaks - was left over 6 months.
I have studded the walls (leaving a 25mm gap between wall and stud framework) using metal stud and insulated between with bats, my next step is to add a VCL and use a insulated plasterboard on top. Before I do the PB I have concerns regarding humidity levels and condensation.
Humidity levels were up to 85% today
The lower parts of the walls I can see water beading (behind the metal stud)
The lower parts of the wall temp reads close to the Dew Point
I left all 3 windows open, and the humidity levels dropped to 75%.
I understand that the downside to tanking a wall means it also stops it from breathing. Which I believe is the case here.
As I am insulating away from the wall and creating a warm airspace within the room, it is leaving the 25mm void and the walls even cooler.
I have setup a dehumidifier to see how that affects the humidity level over night.
Any suggestions on what other steps I can take here? I have seen anti condensation paint, any good? > https://www.permagard.co.uk/anti-co...w6I9MsyxysIjoavDCo6I2Yfrr3F1nC9hoCeeoQAvD_BwE
One of the key factors with condensation is sufficient ventilation to create an airflow so i would look at the location of any airbricks or other provision for ventilating the space.
Dehumidifier
Extractor fans
Opening windows
Applying anti condensation paint
Thing is, if I didn't do the stud work and insulation, then the walls would have been warmer, and less condensation!
It is a below ground structure. Expect a monumental battle with damp, condensation and mouldy smell - or live with it.
There is no such thing.
It's paint with mould inhibitors that's all.
The design ethos of basement waterproofing is that all systems will fail and so a secondary system (drain and pump) is required.
Specific ventilation and insulation consideration is also required. Eg, open your three windows in winter and see what happens with the humidity.
