Lack of covering, per se, is not an issue. However, there could be something said about the 'vulnerability to mechanical damage# (e..g. people kicking them etc.!) of those cables down on the floor. 'Covering' them would be one solution to that, but merely 're-routing (away from the floor) would probably be adequate.I’m having an EICR in one of the rentals. Do I need to cover these cables that are coming out of the CU? It has passed its previous EICR.
Even a cable with a sheath (which all touchable cables are required to have) is still required to be installed in such a manner as to minimise the risk of mechanical damage (despite the sheath). Otherwise, a plastic-sheathed cable (without any other protection) lying on the surface of a flower bed would be acceptable.The sheath is the mechanical protection.
I`m not sure I totally agree there.The sheath is the mechanical protection.
Totally off-topic, but ...Ban was a pretty clever fellah, well researched well educated and he was (nearly) always right. OK his delivery of his answers sometimes rubbed folks up the wrong way (I think he enjoyed a good old joust) but you would cross swords at your peril.
At one time I believed BAS and W were one and the same person, I often noticed they were pedantically saying similar things.Totally off-topic, but ...
I couldn't agree more (and have said the same many times in the past). I remain in touch with him and, although he caused me a significant amount of 'heartache' when he was here, on balance I would very much like to see him back.
After a few fairly short periods of enforced absence, the person whose behaviour caused him to 'withdraw' now seems to have finally 'disappeared' (again, presumably not of his own doing!),having last posted on 27th February, with his profile now 'not available'. If BAS could be convinced that the person is never going to be allowed to return, I might be able to persuade him to 're-join the flock'.
I definitely wouldn't agree with that. Intellectually speaking, the two were/are on totally different planets - and, in dramatic contrast with the situation with BAS, I struggle to recall anything particularly useful, let alone 'valuable', that the other one ever wrote!At one time I believed BAS and W were one and the same person, I often noticed they were pedantically saying similar things.
One of them certainly did. BAS often 'over-complicated' things with (albeit often 'valid') distractions/tangents/pedanticisms, and gave a lot of very good advice himself, but, as above, I can think of little/nothing positive to say about the other one!I for one often thought both got in the way of useful and suitable advice,
I've lived with both of them in the past, and would not let the presence of any individual cause me to 'pull out' - after all, one can always 'ignore' (both literally and technologically) anyone of one's choice.I'd probably consider pulling out if either return.
I would think that ,in this case, 'hiding ' would really amount to 'fixing', since, as far as I can see/think, the only thing really wrong with those tails is their potential susceptibility to 'mechanical damage' (which risk would probably be dramatically reduced by whatever was 'hiding' them).I suspect that the person doing an EICR will find more so probably best to leave it to see what is found before trying to fix (hide) it.
