A pollen filter can protect the people, but not the engine.
Correct. But they can get choked up, even wet and smelly.
Not mine - wet. I hoover mine once a blue moon.Correct. But they can get choked up, even wet and smelly.
A race car.@Londoner2 What sort of car have you got that needs a fuel filter every year? And 2 oil filters? And plugs every 40k?
Mine never have.Correct. But they can get choked up, even wet and smelly.
Mine never have.
I clear the compartment drain every time I polish the engine.
VW passat B5.Yep, dead leaves are the main culprit. I once had to find a water leak on a car that had the cabin filter fitted in the scuttle that had blocked drains. I can’t remember what car it was now but the blockage was so severe it had caused the water level in the scuttle to rise and overspill through the filter into the cabin. It was about 5” deep and you could hear it sloshing about when you drove the car. Customer complained of the leak, ineffective heater blower and windscreen misting!
2 oil changes on any cars is best if you keeping a car for some time.A pollen filter can protect the people, but not the engine.
I used to have a mondeo 2007 tdci, they were fuel sensitive to fuel so fuel filter change every year.A pollen filter can protect the people, but not the engine.
The risk of engine damage due to wear n tear and high oil consumption is higher in older cars, thats why i have 2 oil changes on my 14 year old car.What makes you think that the manufacturers recommendation is wrong?
What are you expecting to happen to my 18 year old car?
I did, just think about the reply.You didn't answer my two questions.
Oil change is down to how much use the engine gets. Once a year is sufficient for most, unless treated very hard or excess mileage.2 oil changes on any cars is best if you keeping a car for some time.
today i drive a mazada petrol high milege so oil x 2 changes n plugs every 40 k, i just use the 5w30 mannol oil.
