- Joined
- 27 Jan 2008
- Messages
- 29,230
- Reaction score
- 3,584
- Location
- Country
An EICR is what one guy thinks the installation is like. There are some clear requirements, like no holes larger that 12.5 mm where some one can poke there finger in and get a shock, and that means E14, E27, and BA22d bulb holders should be banned, this is clearly not the case, yes there are some safety versions for table lamps, and the regulations do allow them as in the main there should be a bulb in the holder.
But I did get a shock as a small child due to sticking my fingers in a bulb holder, I have never done it again, but 230 volt is potentially dangerous, so hard to say any report is wrong, even if we would award a different code.
For the landlord EICR it states
There has been one court case I know of where the inspector passed a property when it should not have really passed, trading standards fought the case, but not seen a single court case where the electrician failed the property when he should have passed it, so simply fact is if in doubt fail it. Once failed you need paperwork to show work has been done, which if there was nothing wrong, is not going to be easy.
However it does not require a new EICR, only paperwork to show work done. To do a whole house would likely take half a day or more, if testing all items. However the EICR is not domestic only, and commercially it is often done on a % of the installation and if all inspected and tested is OK then assumed that not tested and inspected is also OK. Idea is different part tested each time. Often done every year, so over 5 years all should be covered. This is clearly not what the government wants with an EICR in a rental property, in fact
For the electrician to remove covers from boilers to inspect how connected in some cases would require him to be gas safe, we would normally include fixed lighting with an EICR, but very little else, however we would also inspect the DNO side, of electrical supply meter although visual inspection as can't break seals, which is not part of the landlord law.
Putting it in a nut shell, the EICR is not like a MOT and for safety of tenants not really fit for purpose. As with many laws, over the years it will be refined with case law, but it still remains even if each version of the wiring regulations state it is the design date that matters, and if it was permitted when designed, there is nothing forcing one to change it. However things have changed, for example 13th editions referred to "Lighting fittings using filament lamps" since we no longer have filament lamps, at least the type it refers to, then that version can't be used any more. The same applies with EV charging points, solar panels, and even switch mode power supplies, things have moved on, and before 1992 there was no BS 7671.
We have also broken the rules with most homes, wiring should be sleeved the correct colour, but in real terms far easier to work with three different colours in a cable to having three browns, pobodies nerfect, look hard enough one can always find errors.
So there was a change the periodic inspection report (PIR) became the electrical installation inspection report (EICR) and code 4 = does not conform with current BS7671 as if a new installation was dropped as being unhelpful and confusing to the client, and a C was added to the codes to show being done to new standards, and we got the C2 = potential dangerous which is also not really helpful as all 230 volt is potential dangerous, but it allowed the client to prioritise clearly C1 = dangerous done first, then C2 and finally C3 = improvement recommended. It was never designed to be enforceable by law, clearly the HSE would take a dim view, and should anyone be injured the landlord would likely be found guilty, but the whole idea of giving the landlord 28 days to correct faults is crazy, in some cases it should be corrected before the inspector leaves, in other it could take 6 months to arrange for a complete house re-wire. When I moved into this house, it took me 6 months to fit RCD protection to all circuits, what should the landlord do? Turn off all circuits which have failed, kick the tenant out until fixed, a house is not like a wagon or car where one can say beyond economic repair so scrap it, were are the tenants to go? Even in this little village I found a father and son living in a tent in March in torrential rain. Any house must be better than that.
nothing about being a scheme member, having C&G 2391 or any other qualification.“qualified person” means a person competent to undertake the inspection and testing required under regulation 3(1) and any further investigative or remedial work in accordance with the electrical safety standards;
but the IET has a different definition“electrical installation” means fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter;
And items like the boiler, cooker, immersion heater or current using equipment would be tested as part of the "inspection and testing of in service electrical equipment". Often called PAT testing.Electrical installation (abbr: installation). An assembly of associated electrical equipment having co-ordinated characteristics to fulfil Specific purposes.
