For my loft project I was going to cut out holes in the walls and install 8x2 joists to sit in the walls, I don't think I can do that and have decided to use 8x2 masonry hangers instead. The problem is how to do so? The walls are already up so how do i cut the bricks, get the hangers in and then drill and/or use bolts to secure them to the brick, I am a little confused. Can I use a circular saw and cut a line in the bricks and push the hangers in? If I was to do this would the hangers hold the joists?
Is there an easier way to do this? Do strong hangers exist which can be drilled into the brick and then hold 8x2 joists?
