Boiler Flue
11 Dec 2020
I have a boiler where the flue (dual flue) runs across the ceiling (with hatches in the ceiling) to the outside. My neighbour had their replaced but was advised to put the boiler on the outside wall as the flue is required to be changed and it sounded like a large/expensive job.
I wondered what my options were, when I come to replace my boiler as it's getting very old and I have a feeling it won't be too long before it fails. . I don't fancy moving the boiler in my front room so it can be attached to the outside wall.
Should I consider an electric boiler as an alternative ?
It's a flat, so the living room is the nearest room with an outside wall.
The boiler is Ferroli
Ah, ok, so you don't have a rear outside wall and only the front room on the outside wall?
What's to stop you using the duct/ceiling that the current flue is in? How long is the run and how is it enclosed just now, is it part of a lowered ceiling or a boxed section on it's own?
