I was imagining in the region of the original quote that I have had. But I don't know.
Multiply that by 4 at least and bear in mind that’s no hands on experience either
Why not? Seems straightforward to me. Otherwise I don't even know if what I'm being provided with is an improvement.I never entertain customers buying kit like CUs
I always fit the same make and carry a box of spares in my van
OK, well then at least I need him to tell me exactly what he's fitting before he does it so I can then clear it with the landlord/insurers. Otherwise I run the risk of them going "Sorry this doesn't meet Regulation xyz, you need to redo it." Fit for purpose is very subjective. I consider the current unit to be fit for purpose, the landlord doesn't.If you buy something from one of the Sheds it may or may not be up to the current Regulations. If any electrician worth his salt supplies you a board it should be fit for purpose.
No, it is not your responsibility. Leave it to the landlord.so I can then clear it with the landlord/insurers.
Yes. So leave it to the landlord.Otherwise I run the risk of them going "Sorry this doesn't meet Regulation xyz, you need to redo it.
Keep it then." Fit for purpose is very subjective. I consider the current unit to be fit for purpose, the landlord doesn't.
Keep it then.
There; that's that settled.
So why do you think this covenant made by me in the lease is invalid:
"24. Not to do or suffer to be done anything which shall or may make the Landlord's policy or policies of insurance on the Building or any part thereof void or voidable or which may render any increased premium or premiums to become payable and to repay to the Landlord the amount of any such increase payable as the result thereof and to indemnify the Landlord against any breach of this covenant"?
The Landlord says that he will tell the insurers that my fuse board is outdated and charge me any extra premium that they charge in respect of it (as they probably will), if I don't get it sorted. The fuse box is part of my flat, it's not part of the common parts. I'm still not sure whether you understand that I have the flat on a very long lease, and it's more akin to owning it than being a renter. But technically I have a lease subject to the landlord's ownership of the freehold.
