A small flex outlet plate?
22 Jan 2012
UK
Hi all,
I am finding myself needing a flex outlet for 2 cables, but narrower than a standard flex outlet plate. I have searched for architrave sized ones, but nothing seems to exist. I also cannot find any adaptable boxes that are any smaller than a standard 1gang box.
This is for a hot water cylinder with 2 elements. The pipework for some under floor heating is in the way of fitting a full-sized blanking plate.
Does anyone have any creative suggestions, including strain relief, and accessible terminals?
Many thanks
Tim
Trouser/Yee conduit box?
Couple of thro' boxes above one another with domed lids?
Should fit in 60mm rather than 85mm ish?
Trouser box looks promising... do you reckon I'd get 5 terminals and cables into one? Any suggestions for strain relief?
Cannot find a through box with domed lid, any chance of a link?
Many thanks
Tim
This is very helpful, thanks. I was thinking of a PVC box, but I think only the metal ones will have threaded legs to take a stuffing gland?
I'll size them up in the shop, I could either use a 2 leg if I think I can get 5 connections inside (I'd bridge the earths), or use 2x 1 leg boxes if it looks too tight. (2 flex, 2x 2.5mm t+e)
Thanks again, great advice
Put flex outlets somewhere else and P clip the flexes on the surface to where you want them to eminate from?
How about extending the feed using T&E clipped to the wall and putting a pattress box with flex outlet in a more convenient spot?
