Quite right, radials are not needed.If you say so. Only one of them is not needed.
Yes I do say so, they both have advantages and disadvatagesDid you mean "not still needed" and "imply".
Yes they were needed when they were devised until MCBs were introduced.
As I'm sure you know, they allowed 15A radial circuits to be extended into a ring with a 30A fuse using the same sized cable that would not be adequate for a 30A radial.
Bear in mind a radial circuit with 30A BS3036 fuse today would require 6mm² cable.
Yes, with MCBs without the derating factor of BS3036 fuses.
Obviously.
That is not what outdated means.
I like that tongue in cheeck commentQuite right, radials are not needed.![]()
Which is actually completely accurate.I like that tongue in cheeck comment![]()
No.Surely infer or imply could both be used in this situation,
Exactly.they have different meanings though.
If not a joke; would you care to explain?Which is actually completely accurate.
I would hate to be restricted to cumbersome and expensive 4 or 6mm² radials in single backboxes.Yes I do say so, they both have advantages and disadvatages
Why not??
and both meanings (Assuming my understanding of these words hasn't changed since being at school) are an acceptable use in the question.Exactly.
Every single circuit can be implemented using a ring final. If you are aware of circuit design requirements you wouldn't need an explanation.If not a joke; would you care to explain?
Because as you said they mean different things.Why not??
How can they be?and both meanings (Assuming my understanding of these words hasn't changed since being at school) are an acceptable use in the question.
You know perfectly well that we are talking about the UK ring circuit according to 433.1.204.Every single circuit can be implemented using a ring final. If you are aware of circuit design requirements you wouldn't need an explanation.
I would personally not regard 4mm² as particularly 'cumbersome' and, in fact, generally find it nicer to work with than 2.5mm².I would hate to be restricted to cumbersome and expensive 4 or 6mm² radials in single backboxes.
I apologise for believing Mister Amos, my English teacher for getting it wrong.Oh dear. Are you serious?
Put simply: Imply is what someone else suggests to you and infer is what you deduce from that suggestion.
Therefore: If someone is citing the regs as proof that the current rules for our 'standard' ring final is outdated and incorrect (I apologise in advance if my conclusion in this matter is incorrect), on that basis I'd expect the correct word to be infer.How can they be?
Given that the question regarding ring circuits - "If they are still needed, does that infer the were ever needed?" - does not actually make sense but should read "If they are not still needed, does that imply they were never needed?".
Equally you know perfectly well ring finals are permitted to any design and were in place for at least 50 years before some idiot designed our horrible 13A plug. Nowhere in the thread does it mention a specific design of ring circuit, it is of course easy to make assumptions.You know perfectly well that we are talking about the UK ring circuit according to 433.1.204.
Are you saying a ring final with 1mm² T&E with a 25A MCB would be compliant with the regulation and if so, why would you bother to do it?
Edit - just added the 'y' - another mistake I missed.
Hey, folks, Friday is quite a long way offI apologise for believing Mister Amos, my English teacher for getting it wrong. ... As I understood his tuition; ............................
.... To be fair, I think your exchange with EFLI is probably somewhat 'at cross-purposes, be that deliberately on the part of one (or both!) of you, or 'accidental' ....... Equally you know perfectly well ring finals are permitted to any design and were in place for at least 50 years before some idiot designed our horrible 13A plug. Nowhere in the thread does it mention a specific design of ring circuit, it is of course easy to make assumptions. .... The whole of my working life has been based in commercial environments, the last new ring circuits I've installed being 1ph 80A using 6mm² singles ....
Then Ebee's post #10.Not a regulation. As you well know, it is just a recommendation as one of the ways that could be employed to reduce possible loading issues on our out-dated ring final circuits.
Define the term "out-dated ring final circuits"
Then define the term "out-dated radial final circuits"
Yes of course there is but I've also worked on a few 40A domesic ring finals, a local developement listed as a feature in their 'luxury' houses and took me by surprise when I first encountered one.Blimey!
Dare I mention that there might well be a distinction between "ring finals" often found in domestic wiring and "ring mains" often found in the street outside or at power/distribution and transmittion systems.
Quite soBlimey!
Indeed. but (despite misuse of the technical term by many people) "ring mains" are obviously a totally different kettle of fish, other than, of course, that they physically exist as a cable wired as a ring.Dare I mention that there might well be a distinction between "ring finals" often found in domestic wiring and "ring mains" often found in the street outside or at power/distribution and transmittion systems.
