- Joined
- 8 May 2017
- Messages
- 10,633
- Reaction score
- 2,866
- Country
What type of external stopcock is it ? You can buy a street key for a few quid. Do you have a water meter externally ?
No water meter. I've not physically looked to see what it looks like.What type of external stopcock is it ? You can buy a street key for a few quid. Do you have a water meter externally ?
CombiGo take a look ,it may just have a handle like a garden tap.
What provides your hot water ,combi boiler,hot water cylinder ?
It's about a quarter flow. If I leave downstairs and basin tap on upstairs I might get away with it.Is bathroom upstairs ?
How much flow does the internal stopcock allow to pass ,is it a dribble or stronger ?
Just turned on basin with downstairs tap on and no water comes out.The basin is higher than the bath ,so no benefit.
Turn electric off to boiler and run downstairs hot and cold taps on full. That should reduce flow to bath cold enough for you to remove Flexi and fit isolator,working quickly !!
The isolation valve had a flat face male end, and the flexi has a male end too. New flexi fit existing olive perfectly.The isolation valve In your pic should fit ok ? Was the issue that there was a little too much copper pipe ( after the olive) ,so when the pipe was inserted into the isolation valve the olive didn't reach the valve ,and nor did the compression nut ? Was that the issue ?
