And me. What does it mean?I do think that they could have made this clearer for the average user.
It comes from the spec in the Wago document ti which was linked to -it's the difference between "IEC/EN ratings" (at 450V) and "UL ratings" (at 600V).Where did you see that? It shows 20A @ 300V.
It'll be "permitted temperature rise" or somesuch which may even be measured over different time periods.However, U suspect that the difference between the two in current ratings is not entirely (or necessarily at all) related to the voltage - since I can't really see why 'voltage' has go it anything to do with a connector's ability to carry current. All a connector knows about voltage is the very tiny pd across it - and it doesn't know whether the circuit in question involves voltages of 1V, 50V, 500V or 50,000V (all 'relative to something'!).
Yep, very probably something kike that - but, as I said, certainly nothing to do with 'circuit voltage'(of which a connector has no knowledge!It'll be "permitted temperature rise" or somesuch which may even be measured over different time periods.
I don't doubt that.Given Flameport's test videos of overloading Wagos to ridiculous levels the cables would be glowing red hot all over the place before the connector fails.
Inside partition walls. I suppose I need to make them waterproof, it is in the loft and leaks are common in my roof. Maybe wrap them really tight inside a few latex/nitrile gloves.should have green/yellow sleeving on the earths - and where are they going to be - i would put in a box
Thanks. Interesting. As I recent wrote, I'm a little surprised that I wrote it quite like that, although I did add that the comment was for people who were concerned about current ratings of connectors (and that I was not one of them!). However, my comment was in responded to your ...For what it's worth, here is the other thread in question: https://www.diynot.com/diy/threads/...this-with-a-junction-box.603489/#post-5389267
... and, as I recently wrote, I don't think that it is as simple as that.In fact 20A is sufficient for a Ring Final as that is the requirement for the cable itself.
I was also thinking it is bad enough I inadvertently cut those cables with the angle grinder due to extreme clumsiness and stupidity, now with these connectors I may be introducing some extra resistance at that junction, so to remedy the clumsiness I should use the best connector there is. Tomorrow I will remove the wagos and install terminal blocks!However, I'm not so sure about these newer-fangled connectors - with, as has been said, seemingly some pretty small contact areas and possibly diminutive internal conductors!
