Excellent never fitted one but says they are crap and if you actually read the thread its been pointed out that its the old 630 not the new mark 2 .Haven't had a bad experience as I wouldn't ever fit one. Not the same boiler any more either - the Main Eco is the same as the old 830, not the new one. Crap modulation - Main's minimum is 6.9kW, the 830 mk 2 is 6kW, both therefore likely to be massively oversized at minimum output for @chilli_Flake 's 7 radiator system in all but the very coldest outside temperatures. Almost no installer parameters available to set it up to the system it's fitted to - can't even range rate them. Vokera Vibe Max is far superior for very similar money to the Main.
As for oversized in your opinion hence why you use the word "likely" and in the real world does it make any real difference no.
First time i have ever heard the word superior and vokera used in same sentence but each to their own
