Looking for this type of connector that will fit inside a light fitting, something that isn't much bigger than a generic ceiling rose. I have used click connectors for downlighters with great success but they are too big for the fitting I am thinking about using it for.
It's to make it easier to remove to clean a circular kitchen central light with 3 spot lights, the spiders love it and with a family (teens) that like frying food but forget the extractor exists the webs get greasy so not the easiest to clean. I can either use a ladder and get aching arms trying to clean it in situ or disconnect it and get the same achy arms trying to reconnect the wires in the whilst holding the light fitting (and keeping the electrics off for ages) Both these prospects put me off cleaning it until it gets really bad (and usually when I need to replace a light bulb....)
Ideal would be undo central fixing screw, unclick connector, remove, clean (not immersing in water!) and reconnect. Not needing to touch a wire....so not a wago type fitting (although that is my next option as better than current screwed terminal block).
Thanks in advance!
Thanks in advance!
