- Joined
- 31 May 2016
- Messages
- 26,469
- Reaction score
- 6,109
- Country
Just have 996 spare if you want free delivery.
Yeah but with vat and delivery…£5.5160p for next time
No. I bought plasterboard boxes. Even so, the two 20A double pole switches I bought the other day didn’t come with screws.Were the screws not supplied?
You must have found some proper cheapo ones then if they didn't provide the screws. They're usually clipped into the back of the switch if they're not in a separate little plastic packet.No. I bought plasterboard boxes. Even so, the two 20A double pole switches I bought the other day didn’t come with screws.
I bought this one - it was the only make they had in a double. None of them were in packets or boxes, they were all loose.You must have found some proper cheapo ones then if they didn't provide the screws. They're usually clipped into the back of the switch if they're not in a separate little plastic packet.
I always find the longer screws easer to fit, and if you have tiling, etc the extra length is handy. You can always chop them shorter where needed with the wire cutting part of a pair of pliers.
Just checked and they have them in a little packet inside the plastic bag.The screws come with the switches or the plugs, rather than the back boxes. I was thinking your 20A switches will have then on the rear of the switch![]()
Re wired two houses now and it has never caused me an issue doing it the way I described.Which will completely bugger up the thread! Best gadget I've found, is a cheap crimper, is has a series of different sized threaded holes, one of which is 3.5mm, with a matching clearance drilled hole in the other part of the crimper. Squeeze, and it neatly chops the screw, unscrew the screw, and it tidies up the thread. As a crimper, totally useless.
Don’t think so, those screws are pretty soft.Thinking your wire cutter may now be blunt though.
