Me neither, though I do wonder what percentage of offenders actually get 'hit'Indeeed. Personally, I'm pretty sanguine about it, but I know it upsets some folk.
I got to thinking! Would it be possble to make or modify an existing car with controller, that connected the accelerator and brake to the motor/battery, and do without all of the technology?
C.
Hi, Replying to the 'None smart electronics' replies.
The electric motors in cars aren't like the dc Scalextric motors with their slidable potentiometer, but are brushless switched motors. I use these in other projects, and they're much more efficient. With some careful computer techlogogy, it shouldn't be difficult to design a minimum control system, that was efficient.
As for regenerative braking, I don't think this is too complicated either, it just uses the motors in reverse at varying degrees, chosen by the user.
Yes, it has to be absolutely reliable, and tested with all of the approvals needed for compliance. There are companies converting vehicles from I.C.E. to electric, so it can be done. It could be as simple as converting an electric vehicle to and electric vehicle!
I'm sure we can beat and electric milk float
So, would you be interested, in favour of what's offered at the moment?
I know there are cameras, but let's start somewhere, to reduce the sharing, instead of simple acceptance.
Remember, you can always broadcast that you were speeding or in a particular place if you're happy with it
C
Strangely, you've just rekindled memories of being driven around by Dad, in one of his old Minis - it was always fun when the needle was pointing straight downwards!I don't mind admitting that my speedometer might, occasionally, have displayed a number in excess of the posted limit...
...shocking how inaccurate some speedometers can be...![]()
Hi,Believe it or not, some DO use brushed motor! I was surprised to find that mine does:
(Not that I have an M60, though, but my i4 has a (smaller) brushed motor).
That's the easy bit. It's modulating (or even turning it off altogether in a fraction of a second when grip is compromised), that's the complicated bit!
If you want to type approve it like a mainstream car, forget it. It will need ABS and Advanced Emergency Braking. Things will get incredibly complicated and expensive. You can get away with less if you go for a "small series" approval, and less again, if you go for an Individual Vehicle Approval (which is really the only option for a DIY one-off). However, you'll still need to manage the regen. We tried this at work about a decade ago. Realistically, as a DIY proposition, we stood no chance of integrating the regen with the car's existing foundation braking system. The best we could do, was put a pressure switch in one of the front brake lines, so that regen could only start once there was a small amount of pressure in the brake line. We then fitted a "CAN sniffer" to listen out for the CAN signal that said an ABS or ESC intervention was happening, and cut off all regen braking instantly, but it wasn't very statisfactory. People converting old ICE cars to EV, are exploiting a legal loophole where the brakes only have to meet the braking requirements that were in force at the time the base vehicle was made. Given that most of them were made long before ABS and ESC and Electronic Brake Force Distribution was "a thing", they have virtually no legal requirements to meet for brakes. As a result, I think many of them will be unsafe, to varying degrees!
Your BMW brushed motor link was interesting, although I wouldn't want to change the brushes, they're not like my black and decker ones.
It just shows what can be done.
I once nearly had an accident because of ABS brakes, on the ice. I was trying to control my van by braking as I've always done in these conditions, but the ABS kept making me skid more. So this one wasn't perfect, and I'm sure it could be done independently, of motor companies, obviously it would have to be by other certified companies. I'm no expert, but is it possible to use the existing 'old' car computer, with ABS and control the drive separately.
I just delivered a 30 year old MX5 250 miles (a brilliant top down drive) and I'm sure both the speedo and rev counter were a bit out for some of the journey. Having said the 3 cars shot by me, I think they were racing, and my goodness they were impressive.
C
Hi A,It can be done, as I outlined above, but it's nothing like as good as a properly integrated system. Personally, I'd rather just take the benefits of a modern system and put up with the complexity that goes with it.
Sounds like fun. I like old cars (I have a 35 year old saloon myself), but I'm a firm believer in leaving the past in the past. I hate these retrofit EV conversions to classic cars! Like putting a Pendolino motor under the Flying Scotsman!
Hi A,
I'm sure many agree with you, but for us with other views, I hope some company does show interest, and develop something equal to the manufacturers control system, with only the extras that the customer wants, so everybody will be happy
C.
Hi A,I wish you well with that, but in my view it is not practicable. You want:
(a) a controller, that connected the accelerator and brake to the motor/battery, and do without all of the technology;
(b) a system that is absolutely reliable, and tested with all of the approvals needed for compliance; and;
(c) something equal to the manufacturers control system, with only the extras that the customer wants.
I think those a mutually exclusive wishes. I don't believe you will ever get anything even remotely equal to the manufacturer's control system, without the expense and complexity of the manufacturer's control system.
Well! I bought a car, after kind of accepting the inevitable, to find that the connections had not been set up, so the car is 'clean' When I switch on (hybrid) a screen pops up asking if I want to notify the manufacturer of such things as location, I click NO, and the car runs.
It will collect DATA, e,g, battery condition, which I don't mind, as it help with development.
So if I'm correct and it doesn't report my location, I'm happy.
Cheers, Camerart.
Dogging site.I've never been able to work out why one of my local parks becomes surprisingly busy, at around 2am![]()
Hi A,How old is the car? I have a friend who does work for the government that he isn't allowed to talk about much. He recently had to forensically strip a few new cars. I really mean "strip" - right down to circuit boards and individual processors in electronic control units. On all of them, they found devices capable of transmitting wireless data. On one of the cars, he and his team found a total of 5 devices within the car, capable of transmitting data wirelessly. The car manufacturer only knew about three of them...
Like it or not, all modern consumer goods will tell people things about us. If you have a mobile phone with sat-nav, it might be doing it right now...
Hi A,
New.
As mentioned previously, I know they all have SIM cards, and if wanted the police can stop a vehicle. It will be interesting once they start using this, as I think it would wake many up!
In a way I don't mind them monitoring data for use in improving etc, as the bee in my bonet is location. I have the data switched off on my phone, so it is only a sim phone, till I need data, I also know how they can work out where you are by lining up roads with the phone tower data I understand that AI could probably tell where I am by methods I can't imagine.
Anyway I've done it now, so I'll try not to think too much about it.
C.
