recoup.co.uk
Ah I see what you mean, well theoretically yes but it all comes down to the cylinder recovery - coil output, CH flow temps, cw temp etc.Regarding my "constant hot water" if my hot water is timed on, my 145l cylinder is up to temperature, my shower is 8l/min, my boiler is 15kw and my recoup is pre heating the cold into the shower I recon I could shower for hours without running out.
I notice that @cdbe doesn't seem to have his attached, maybe that's why he got it at an 85% discount![]()
I think you're probably right to be sceptical about the ROI. Hard to find much obviously independent information on ROI for these systems. Only a handful of manufacturers.I doubt you'd ever recover the installation and manucturing energy needed to install heat recovery from a drain. The waste from a shower isn't very warm, as it gets blown through the air, just like a cooling tower in fact.
Lots of relevant comments here:
Waste Water Heat Recovery Systems – TheGreenAge
www.thegreenage.co.uk
