EDIT - I've also noticed a wider crack on the exterior of the downstairs window and a hairline stair step crack on the ground floor exterior. Images attached.
I've already booked a structural engineer to take a look, but I'm curious about your thoughts in the meantime as they can't come for a few weeks. I have a crack in my front bedroom underneath the window. The top part is about 2mm and has been there for a few years. However, since at least April '24, it's migrated downwards.
I've only recently noticed the crack on the outside, which looks like it's in the same position under the window on the right-hand side (directly below the outer part of the window). It's only a hairline crack, but both together worry me.
Little bit of context - the house is a 6.5 year old mid-terrace newbuild built on clay soil. My neighbour on the end has just had remedial works completed for subsidence (caused by neighbouring bushes which have been cut back. She's also had a trench dug out next to her house and filled with copper sheeting and gravel). I had someone out at the start of last year who said I didn't have subsidence, but the cracks have since got worse. Is it possible that her subsidence is having an effect on my home?
Thanks in advance.
Thanks in advance.
