Vokera Easiheat i25c opentherm
23 Nov 2024
Hi all, I have a Vokera easiheat i25c boiler and I am currently trying to swap out my draytin timer for drayton wiser controls. The issue is have is that when wiring it as per manual I am not getting opentherm control. I am.womdering if there is any steps I am missing to get this to work. I have attached pics pic of my boiler its board and wiring diagrams to see if it helps. Thanks Andy
Previous was just a timer and it was fitted to terminals 1+2 where the bridge can currently be seen. Bridge has been refitted just to enable use of boiler while I sort the issue.
The bridge is vokera original just refitted.
Thanks, I'll try that tomorrow. Just to check I'm reading it right opentherm is terminals 2 & 4?
No luck with that. Not sure if wiring is incorrect the stat isn't compatible or there's a bigger issue?
Thanks for that, much appreciated. Wired that way works. Not sure if manual.is wrong or if it SHOULD work when wired the way in the manual but that way works when others didn't.
I can see that this could be a bit confusing, but the picture is showing the board edge and cutouts of the PCB, it isn't showing which terminals the OT wires should go into.
