You may have fuses in line and neutral in Australia, we did have at one point 110 volt plugs with fuses for both lines, but in the UK the fuse is only on the line pin, the neutral is not fused, so heat from fuse will be concentrated on the line pin.Obviously, BOTH the Line and Neutral pins and socket contacts are carrying the same current.
Australian Plugs do not have Fuses in them.You may have fuses in line and neutral in Australia, we did have at one point 110 volt plugs with fuses for both lines, but in the UK the fuse is only on the line pin, the neutral is not fused, so heat from fuse will be concentrated on the line pin.
should really be banned, they put a thermal overload on the incoming supply,
they are OK, it is the yellow brick which is the problem.
but most of us expect fuses bought over the counter to be genuine, I find I buy 3 amp and maybe 5 and 7 amp, but 13 amp I gain as changed when wrong size found, so my 13 amp fuses could come from anywhere.However out 13 amp plug and socket is what we are talking about, and again the new safety feature has resulted in the line and neutral pins being reduced in size and insulation put on them to stop one being able to touch live pins when inserting or removing, and this in turn has reduced the heat transfer into the socket, so the plugs tend to run hotter.
I think it probably does but to what extent I`m not sure.how does the "half-insulation" reduce the heat transfer to the socket "fingers"?
Heat travels by Conduction, Convection and Radiation.I think it probably does but to what extent I`m not sure.
Take two pins of the same size and CSA, part cover one with electrical insulation should increase a bit of thermal insulation too?
the contact springs on a socket should be the same on both variations therefore heat loss on the insulated pin should be slightly less, how significant I`m not sure though, I would expect that it might run a little warmer as in both variants there will be a bit of air around them.
Just a thought.
This has been stated before
BUT
These "fingers" are in contact with the bare metal of the pins and are not in contact with the insulation.
Hence, even at the greatest likely reduction in the "Heat-Sinking" capacity of a BS 1363 Pin,
it is still over 6 times that of a 2.5 mm² conductor.
However, the "Radiation" would not be Zero, especially if the Insulation were Black.The insulation on the pins, limits the pins ability to radiate the heat, most of which will be produced by the fuse,
"a great deal more from the contacts to the fuse."The insulation on the pins, limits the pins ability to radiate the heat, most of which will be produced by the fuse, and in the case of a worn fuse holder, a great deal more from the contacts to the fuse.
One source (http://hyperphysics.phy-astr.gsu.edu/hbase/Tables/thrcn.html )Brass, has much lower conductivity/higher resistance than copper.
it seems to be a case against having fuses -
gives the comparative thermal conductivity of Brass as compared to Copper as
109/385 = 0.283
