Using rebated fuels in vehicles and machines (Excise Notice 75)
Find out when you can use rebated diesel, biodiesel or kerosene in vehicles and other machinery.www.gov.uk
2.4 Machines and appliances for heating and electricity
Machines and appliances being used primarily to generate heat and electricity for premises that are not used for commercial purposes can use red diesel.
I once recall seeing Bull Electrical offering submarine battery cells !
Ah, that's a piece of string question.But still the same question as last post on this thread, what size inverter needed to start a freezer?
So what was the story there ?Me too! The story of Bull's demise was quite an interesting read..
My upright has an inverter drive, not seen it with chest freezers, and the upright uses around 180 watt for the defrost cycle, so needs around 200 watt inverter to supply it even when run is around 60 watt. And upright use around a 1/3 more to same size chest freezer. So if worried about power cuts would what a chest freezer, a chest freezer will last around 24 hours, but upright depends when the last de-frost cycle was, could be down to an hour if only just finished defrost cycle.These days inverter drives are common and the startup requirements are less.
... which is presumably a good reason for not getting an upright freezer which has 'auto de-front'. After all, we managed without such a facility for decades, didn't we?..... a chest freezer will last around 24 hours, but upright depends when the last de-frost cycle was, could be down to an hour if only just finished defrost cycle.
I think I was just into my teens when I recall looking at the lists from Bull and wondering what my pocket money might buy.
Upright vs. chest is an old discussion. AIUI it's usually down the chest freezers generally having better insulation than uprights. The difference in "stored cold" between pre and post defrost cycle would be minimal IMO - not a large quantity of ice, and being water ice would not help much.So if worried about power cuts would what a chest freezer, a chest freezer will last around 24 hours, but upright depends when the last de-frost cycle was, could be down to an hour if only just finished defrost cycle.
is actually a battery charger, but the start peak is the same pattern with a freezer, we know each start will be the same, but the software does not record them as being the same, so only way to find out is suck it and see, but want to know before one buys a generator or inverter will it work.I'm sure that's one factor. Another is that, even when they have drawers/compartment doors, when one opens an upright thereis an immediate loss of cold air (replaced by warmer air) in a manner which doesn't happen to an appreciable extent when opening a chest freezer.Upright vs. chest is an old discussion. AIUI it's usually down the chest freezers generally having better insulation than uprights.
Probably true but, as I observed, having 'auto defrost' must result in at least some rise of cavity temp during the 'defrost cycle'The difference in "stored cold" between pre and post defrost cycle would be minimal IMO - not a large quantity of ice, and being water ice would not help much.
