Without having to trawl through every post @omph
> what combi boiler is it? This will determine if the system flow temps can be controlled separately which would be needed for any PDHW system
> If you are talking PDHW then you will have a cylinder, is it open vent or unvented?
There are boilers that utilise Open Therm (OT) and that allows for a 'standard' PDHW system setup - if there is such a thing - and others that use their own propriety controls, a bespoke system layout, an addition of hardware/wiring to their standard configuration or an adapter interface or similar.
The most straightforward system, I believe, as has been suggested is the 'X' plan with a NO and a NC 2 port setup or 'D' plan that utlises a 3 port diverter valve, which of these is normally decided by the current system configuration. It can also be easier to have a boiler that natively supports OT 'out of the box' and a well designed OT enabled programmable stat as the user's interface.
Quickest and Easiest explanation I found for PDHW systems is - https://heatingacademynorthampton.co.uk/category/pdhw/ it does get into the nitty gritty of the various ways manufacturers have sought to implement PDHW across a plethora of different systems but it still gets my goat why these manufacturers can't agree to do things the same way and have a standard - which was the whole point of the OT development but they now feel that they all have to be just different enough to make things a lot more complicated when it comes to a independent professional looking to maintain them.
