Hive Install to replace Danfoss TPOne - B
Or is there a wire guide somewhere for a danfoss I could see which black wires go where? Online
. I believe my fault is in the wire box. I have three black wires two of which are from my now hive receivers and the other is going to my pump I believe from the box lable. When I move these around I now have hot radiators around the house but not my zone 2 upstairs
So, have you moved the black wires around in the wiring centre?
Or, for more context....
The guide on the box lid of your wiring centre does not relate to your dual zone setup.
As the TP One-B system was working perfectly, there was no need to touch the wiring centre.
One of the Black wires is a switched live back to the boiler, when there is a call for heat.
There is no separate connection to the pump.
To find out which Black wire is the Boiler S/L, temporarily connect them, one by one (power safely isolated etc.) into terminal 11, with the three brown permanent live wires.
Once you have found the black wire that fires the boiler, this should go into terminal 9.
The other two black wires - the switched lives coming from the Hives - should go into terminals 13 and 15.
Superstar . That has worked . I had 13 and 15 the wrong way round. Then once swapped I had lose connection on zone 2 so wasn't coming on. Now all working. Only slight concern is radiators don't go off completely but I think that has something to do with the hive app and frost protect sstayingon. Thanks again for your patience.
Well done, glad it's sorted. :)
