That's actually something of a concern, if the pull switch is by the door then the triple switch appears to be a long way away from the door.Is it possible this bathroom/wc was wired as 2 way? You say the wall switch and the pull switch are 2 metres away.
Have a look in the pull switch.
That's how I read it. I wondered if perhaps the room had another door to it, from a bedroom perhaps.That's actually something of a concern, if the pull switch is by the door then the triple switch appears to be a long way away from the door.
Tell me about it, even when the person at the other end is supposedly a proThat's how I read it. I wondered if perhaps the room had another door to it, from a bedroom perhaps.
Just guessing really. Hard when you're not actually there with a few tools.
What's the wiring look like in the bathroom pull switch?
It will be live as it's com is linked to another comSimple stuff then.
Once you have discovered if that middle switch is available for use.
Is it live? Do you have any voltage test equipment?
There is no bath or shower.In that case, why not put a light switch in the bathroom itself?
How far would a light switch be from the bath or shower? (ignore the sink as that does not count).
