Hi All,
So I have a Pyronix enforcer (with the WiFi module) fitted around 2022. Albeit I don't know who by, as we bought the house in 2024.
I changed all the shock sensor batteries a few months ago and one PIR that was flagging as low, but not any of the other contact sensors or PIRs.
Yesterday it started flagging "utility dt wireless low battery", so I went and changed the PIR first as I know DT is in the part number for this, and then the contact sensor (as this is the only other sensor in that room which hasn't been changed). This didn't turn off the low battery warning either.
However I am now left with the original fault and also "utility door mc tamper on input" plus "16 utility door tamper on input". So clearly it wasn't either of those and is mislabelled but unlike before with the shock sensors I don't seem able to clear the tamper alerts.
Q1 - Is this because I still have the low battery on "utility DT" ?
Q2 - Is it also fair to say that the Utility DT is likely a PIR and probably just worth me finding all other PIRs and changing those batteries?
Q3 - What would your approach to clearing these errors be? I have heard about powering down/up the panel, but how do you do this when there is a spare battery in it for power cuts, do you need to open both the master panel (under the stairs for me) and also the front door panel?
Q4 - Longer term....I have the master manager code and can add/remove users e.t.c but I don't have the admin code. I understand there are ways of resetting the admin code to default, or generating 'anti codes'....any help would be appreciated in how I go about that.
Thanks !
Thanks !
