Some sockets are/were single pole switching is one reason, the other reason is you would also loose the earth connection by unplugging - unless you did what I did on a LA Grant aided rewire to trap the grants inspector (well he was previously a plumbing/heating engineer so I thought he would snag it). Did not work out how I planned though, he never brought the issue up, I was awaiting his challenge that although isolation would be achieved the earth connection would be lost, I had put an earth link from the socket directly into the boiler to maintain earthing even once unplugged,.Most boilers seem to have a FCU not a plug and socket, so hard to plug into a generator in an emergency without the use of a widow maker, also need a locking off device designed for that make of FCU, to lock the switch off. (The fuse only supplies line, so neutral still connected so technically not isolated) Where if using a 13 amp plug, where these
are universal for all 13 amp plugs.![]()
The only reason I can think of, was some regulations back, we did not need to protect FCU with an RCD, however buried cables in wall rule has in the main change that.
I have asked on Plumbing section it does say in some boiler manuals to use a FCU, likely written before the rules on RCD's changed. So other than that's the way we have always done it, why would one use a FCU to supply a boiler? As to being able to unplug locking sockets would stop thatso why are FCU used to supply boilers? These View attachment 373164 will allow us to have central heating even with a power cut, not sure if 600 watt is enough, but since the use of FCU encourages the use of the widow maker, should a FCU be given a code 2 in an EICR!![]()
That will teach me to be a right smart alec trying to catch him out, it took all of the fun out of it - I must get out more often.
