If you can't find the one I posted to (it was only a quick search), you could "frame" the new openings in the brickwork to create the required depth, ie turn the last full bricks 90° so they stick out say 50mm and fit 50mm offcuts on the opposing courses.
I think moving costs depend on dno and possible distance but I've heard £700 +VAT each as not uncommon, plus you'll probably need a gas safe to redo pipework on your side of meter and spark to extend wiring and relocate the CU - presumably a fair way to get it out of that kitchen area - but bear in mind there may be a limit in length of meter tails allowed so aim for meter and CU to be close together on either side of the wall.
Apologies for my rubbish drawing - it's a side view, but you should get the idea.
