Locks, locks, and more locks. The replacement lock/gearbox for our side/back door arrived today, as did a replacement spring cassette for the handle, so time to make the dog happy(er) and restore use of the door. Since it was freed, earlier in the week , I've been jamming the door shut, with a piece of timber, wedged against the wall opposite. Dog habitually goes out the front door, comes in via the back. Despite the door being out of operation, she has insisted on coming in that way, and no other....
Got the new gearbox onto the multipoint rack, found a couple of rivetted on bits, which had come adrift, and eventually decided they were none essentials just there to keep the rack together, before it was fitted, so cracked on with fitting. I tested it retracted numerous times, locked and unlocked, before chancing actually closing the door and testing it. All worked fine, so then it came to fitting the handles. One of the spring cassettes had a snapped metal centre, so I'd ordered the nearest I could find, but it wasn't near enough, it just didn't fit at all. Then I got bright idea, to see if I could rob it of the metal centre, and just transfer that in place of the faulty part. That worked perfectly - job done, onto the next one...
I've cleared space in my workshop, just to the rear of my garage where I used to park my VFR, which has it's own nice wide access door, in a straight line with my drive. Since I got the new mobility scooter, I've been struggling doing a multipoint U turn, squeezing through a narrow gap between garage and hut, then in and out of a narrow door gap into the hut door. Space cleared, it now drives straight into the workshop, except I had to go in via a third small door at the far side, which has a code lock, just to release the two bolts on that wider door. I decided to order a second code lock for that wider door, I have that lock to install this afternoon.
