If it’s your tap and attached to your neighbours house you have no choice but to remove it urgently
You could just remove the tap, extend the pipework and relocate it somewhere on your side but your neighbor still might not like the fact that the pipe is clipped to their side of the extension.Yeah ongoing dispute result of when they had loft conversion done. Loads of things went wrong flooded our kitchen, blow electrics came through into our side of house. The problem was I complained and that upset them. They never apologised and just not good. They had security camera looking into our house and I asked for it to be moved for privacy reasons. They asked for electric cable to be removed from fence as a response which I did. Now asking for this tap to be removed or else he will remove tap himself.
He cannot put a time frame on it like that, just tell him your on with itI think my main problem is him saying get it done in 7 days. I can’t actually get done in this time frame. My sister is a plumber and explained what would need to be done. My issue is neighbour coming onto my property and removing tap.
What childish behavior.I think my main problem is him saying get it done in 7 days. I can’t actually get done in this time frame. My sister is a plumber and explained what would need to be done. My issue is neighbour coming onto my property and removing tap.
Looking at the way it is installed, I doubt there will be an isolatorWhat childish behavior.
Just find the isolator for the pipe and turn it off and remove the tap by unscrewing it with a spanner. The tap isn't fixed to anything so it should come off.
Job done.
The tap is not attached to anything the pipework has a clip on neighbours wall , unclip and it’s no longer attached to their property . 2 min job.I think my main problem is him saying get it done in 7 days. I can’t actually get done in this time frame. My sister is a plumber and explained what would need to be done. My issue is neighbour coming onto my property and removing tap.
There’s clips on the wall which the pipe is on. He’s also asked me to make good on any damage done to his wall. But seeing as I can’t get down the gap no idea how can do that.The tap is not attached to anything the pipework has a clip on neighbours wall , unclip and it’s no longer attached to their property . 2 min job.
No idea how I can take off the clips on his wall without knocking extension down. I would isolate and remove tap. However he will say to remove clips pipe from his wall even if I remove tap.Just seen your reply posted the same time as mine.
Ask him how you can disconnect the pipe and make good when you cannot reach the pipework.
All you could do is cut off what you can and disconnect at the other end. Then reinstate the pipe and tap using a different route.
If so, then you'll have to get the whole pipe supplying the tap removed.
Surely the water is supplied from your water supply and not the neighbors? Turn on the tap and inspect the water meter.
