Hi all,
I need to insulate and plaster a single brick wall that is part of a stairwell up to a loft conversion. 50% of the wall has an unconverted loft on the other side, the other 50% is straight to the elements. Gets bloody cold in the winter. Size is 4.8m x 4.8m - pic attached.
How would you go about insulating and covering this? There isn’t much depth to play with before it starts impeding on the stairwell space and I want to be really sure that no moisture gets stuck in between the brick and the insulation. I don’t mind if it’s not amazingly well insulated - just has to be better than it is now.
Thinking either a small stud wall with insulation and plaster over that, or insulated plasterboard straight on to the bricks.
Thanks for any advice!
T
T
