I'm beginning to see how your opinion of women and your signature tie up to indicate how far in the past your world view is.
Are you two saying that the two things stated by JohnD and his signature are not the case?Yes, I thought that too.
The vast majority of domestic premises are occupied for much more time than they are unoccupied, so I would personally very much favour coming down on the side of maximising 'protection' when the house was occupied (by NOT having a freezer on a 'dedicated' circuit). Not only is that, statistically, much more likely to avoid loss of freezer contents than would an approach which might be preferable when the premises are unoccupied, but the chances of anything 'tripping' say the circuit supplying a TV whilst the occupants were on holiday would presumably be extremely low?
I'm saying that the attitude that women, specifically, are subject to sudden whims but that doesn't matter to them because they don't have to do anything is desperately outdated.Are you two saying that the two things stated by JohnD and his signature are not the case?
Indeed, and it seems very common that the reason the plug overheats is because of poor connection between the fuse and it's 'holder' (the only other real reason seemingly being 'loose connections' at the terminations)Often as not, it is the plug, rather than the socket, which overheats and causes the problem, damaging both the plug and the socket it is plugged into.
Yes I've seen that situation on some appliancesOften as not, it is the plug, rather than the socket, which overheats and causes the problem, damaging both the plug and the socket it is plugged into.
I've had to do that in my lounge where I've taken cables to the TV over the fireplace (I know, I know, it's her idea!)... I've got co-ax and Cat 6 in the LHS corner and 2.5 in the RHS corner, up to the coving, then along behind the coving, then down behind the TV.I agree, I think the corner zone is madness really, not many non electricians would know about that one.
But have you used the corner zones?
Maybe we should go back to how I assume it used to be done.Yep.
My house built 1930 ish the switch drops are inside metal oval conduit and it's really thick, it's been rewired before I moved in but the metal drops are still there it makes sense to me
Easy to rewire and you cant knock a nail through it.
