- Joined
- 27 Jan 2008
- Messages
- 27,709
- Reaction score
- 3,360
- Location
- Country
For me with solar panels and battery, I can easily work out average price for peak and off-peak for the year, and it comes out at around 19p/kWh when off-peak costs 8.5p/kWh and peak 30.17p/kWh and single rate is 23.86p/kWh so it is clearly worth it to have off-peak supply. OK 67.83p/day standing charge, and the single tariff is 68.17p/day so also a slight gain on standing charge. I am using Octopus prices, but all I am trying to show, is I can with records generated actually compare costs, and off-peak wins.
So now onto storage heaters, my first problem is to find Economy 7 rates, Octopus have Snug, which is 6 hours at night and an hour during the day, and so not easy to get straight answer, but it seems 14.68p/kWh nights and 33.78p/kWh in the day is about right, and to start with this is nowhere near as good as the deal I have for 5 hours, I use 12 kWh per day on average, Economy 7 users normally have smaller homes, so I would say 8 kWh/day without heating is fair guess. So around the £1000 a year for the peak supply. I would guess storage heaters used for half the year, so need to save around £600 with off-peak to break even. So gaining 9.18p for every kWh used, so need to use around 6500 kWh off-peak to break even. So my maths shows around 36 kWh/day.
At this point, I hit a brick wall, likely iron and clay bricks, but finding how many kWh is stored in the bricks, best I could find is
So why are we worried about RTS, seems past it's sell by date anyway. I await with interest to see some one who can show I am wrong. May as well replace with panel heaters?
Example:
But some can fully charge in 5 hours, so it means very little. And this is before will look at less being used Autumn and Spring. But it would seem one would likely need 4 storage heaters at 3 kW to be on the gain. And the question is, do all rooms need heating 24/7, I don't with oil heating, my electronic TRV heads turn on rooms before we are due to use them, and on average only half or less of the house heated at any one time.A 3kW storage heater charging for 8 hours uses 24 kWh of electricity (3kW * 8 hours = 24 kWh). This means it will store enough heat to potentially last for a significant portion of the day, depending on factors like insulation and desired temperature.
