Hi, my son has a double oven that trips the main RCD but only when both ovens are on AND have heated up.
Initially we thought it was the top oven element because he noticed it when he used that oven, so we replaced it but but it turns out it was just that the main oven always happened to be on when he used the top oven, it so it still trips out.
I wondered if it was overloading the circuit but it’s on a dedicated 32a mcb so should be fine, plus the breaker is never tripped, only the main RCD.
I’m loathed to shell out for another two elements because I can’t see why an earth fault would only show if both ovens are hot, but I’m also not an oven expert.
Is this a typical fault that is likely to be one of the other elements or are we looking at something more sinister?
