- Joined
- 6 Nov 2025
- Messages
- 13
- Reaction score
- 0
- Country
I have been renovating my ground floor bathroom and while taking the walls back to brick, I found my mains pipe buried in the wall, going up to the eaves. This prompted me to follow the layout of the mains supply and found that although it starts at the ground floor, instead of supplying the bathroom directly it instead loops over the first floor eaves and then goes back down to the ground floor to supply the ground floor bathroom. I have added a diagram to explain it a bit better.
There is also a capped off and cut 22mm copper pipe going from the loft to the first floor eaves.
Could this be due to an older gravity fed system? The boiler is currently in the kitchen (ground floor).
This mains pipe is lead and is in the way of both my current bathroom renovations and my future eaves renovations, so I was thinking I could just go directly from the ground floor mains pipe to the ground floor bathroom copper pipe and then rip the old lead pipe out from the bathroom wall and the eaves. Any reason I shouldn't do that?
Also in terms of doing that, I have bought a PHILMAC Universal Transition Coupler 21-27mm x 15-21mm. Anything I should be wary of when working with the lead pipe? Do I take the angle grinder to it and then just use the UTC to go to 15mm copper?
