OIL - Atkinson Tankmaster blocked
6 Dec 2025
Afternoon All,
New here so be kind!
We’ve got an Oil boiler for our central heating and hot water and ran out of oil 4 days ago (I know, I know, already had it in the ear from the missus who is currently in labour!).
The long and short of it is that having topped the tank up and attempted to bleed the burner pump, no oil or air was coming through.
Undone the fitting before the fire valve outside, and there is no oil in the line.
Having inspected the tank, I have seen we have a very old and battered Atkinson Tankmaster fitted. The filter has probably never been changed, as with everything in this house it seems bodged and reused within an inch of it’s life.
I’ve pretty heavily researched the valve and think I’ve got my head around how it works. I wanted to check the filter on it and the pipework around it to try and establish if any oil was coming through the valve or if the block is between the Atkinson valve and the fire valve.
On further inspection and attempts to turn the hand wheel. It spins freely in both directions and doesn’t seem to pull the spindle in or out. When I press the spindle it moves in about half a centimetre indicating that the plunger is shut.
Obviously we didn’t have this problem before (that I’m aware of) as our oil was flowing freely.
Any ideas for the best way to rectify it or next steps. Should have the plumber coming back at some point but with an imminent newborn on top of Christmas this could be tricky.
TL;DR: Atkinson Tankmaster wheel spinning freely, spindle is out all the way and oil line is blocked somewhere.
Thanks again! C
If you’re sure the valve is shut, you can take off the bowl on the bottom & check the filter. You might get away with giving it a quick scrub over with an old toothbrush to get you going temporarily.
Is the tank outlet higher or lower than the inlet to the pump.
If the wheel spins freely, then the thermal joint has broken. The nut should still be on the spindle, and can be turned with a spanner to close the valve. The valve is closed when there is no play in the spindle. You can then remove the filter bowl.
I would imagine it’s ever so slightly higher but that would be a complete guess because the run is about 10 metres long.
Would you be able to tell this from an image? I have attached one to this response.
I’m not certain it is. That’s the problem. Didn’t want to take it off if it isn’t actually a bit open.
Remove the circlip from the wheel, and if it spins freely it should pull off easily. If it is still tight, then lever it away. If it spins freely and does not operate the valve, you need a new one any way. With the wheel off, you ill see the nut on the valve stem. Give it a soaking an turn it clockwise with a spanner and the valve will close. you will be unable to push the shaft in. To test if it is closed before removing the filter, unscrew the sight tube from the valve and pull the 'to read' plunger. If oil comes through, then the valve is still open. Just make sure the small hole is clear before pulling the knob so that you can be sure that it is not a blocked hole.
Remove the circlip from the wheel, and if it spins freely it should pull off easily. If it is still tight, then lever it away. If it spins freely and does not operate the valve, you need a new one any way. With the wheel off, you ill see the nut on the valve stem. Give it a soaking a turn it clockwise with a spanner and the valve will close. you will be unable to push the shaft in. To test if it is closed before removing the filter, unscrew the sight tube from the valve and pull the 'to read' plunger. If oil comes through, then the valve is still open. Just make sure the small hole is clear before pulling the knob so that you can be sure that it is not a blocked hole.
Legend. Thanks so much for this.
When you say give it a soaking I’m assuming you mean WD40?
WD40 is not actually very good at freeing off rusted items as all it is a water displacement material. You want to use something actually labelled as a penetrating oil.
Remove the circlip from the wheel, and if it spins freely it should pull off easily. If it is still tight, then lever it away. If it spins freely and does not operate the valve, you need a new one any way. With the wheel off, you I’ll see the nut on the valve stem. Give it a soaking an turn it clockwise with a spanner and the valve will close. you will be unable to push the shaft in. To test if it is closed before removing the filter, unscrew the sight tube from the valve and pull the 'to read' plunger. If oil comes through, then the valve is still open. Just make sure the small hole is clear before pulling the knob so that you can be sure that it is not a blocked hole.
Hello again. Thanks for your help so far. I’ve got the wheel off (what a pain) is the nut you are talking about the bit I’ve highlighted. Sorry I know that’s probably a very dumb question but I just want to be sure!
Turn that clockwise to stop oil? If I turn it anti clockwise will that allow me to slide off the whole body and replace the entire unit?
Not that big nut. Using grips, turn the copper coloured sleeve clockwise, and you will see the centre spindle come outwards and that will turn off the oil.
Just wanted to say thank you for all your help for everyone that replied and helped me. I’ve managed to fully replace the entire Tankmaster unit, bleed the line and get my boiler restarted and heating on.
Couple of pics attached to show the state of the filter and the new unit. Thanks again all, particularly Oilhead, check your private messages mate.
Pictures
Looking at those photos it might be worth checking your tank for water ingress.
I wouldn’t be surprised if it’s never been changed!!! But thank you noted and I will make that my next job.
In the meantime best leave the heating switched off for half an hour or so after future oil deliveries just in case.
