Indeed, and I think you could do that with virtually all makes if CU that had a 'standard/traditional' busbar layout. Despite what you seemed to imply, I see nothing special about Fusebox.
My gut feeling is left is more prevalent these days but don't have any statistics. EDIT: just done a quick google/images and looks like right have the edge but I didn't try to see what makes are shown.
I did the same, and came to the conclusion that 'right' seemed to be a fairly clear winner.
For what it's worth, I've just looked at the CUs offered by TLC. Of the 7 brands they have, only two (MK and Crabtree) appear to have he main switch on the left.
Although I (and others, like EFLI) have been saying or implying that the 'polarity' of the switch does not matter, we had overlooked the fact that one side might be designed to make (and/or break) first. Does anyone know whether this is true of any CU 'Main Switches'?
Some of you might recall, a long time ago, I came to a "conclusion" that a particular DP switch (for an immersion heater) might have one side leading/lagging being perhaps one contributing cause of an RCD trip.
The problem only occored at switch off if I remember correctly. I am guessing now but it was likely an MK switch and had been in some years (probably the "old Logic Range type) and whether by design or wear and tear or a grain of grit/charred contacts might well have been one contributing factor to this problem.
Using standard test gear plus a multimeter etc I could notfind an answer to remedy the problem.
I replaced the switch with one of my own stock therefore differennt make (I have disliked MK for yonks) and hey presto the problem disappeared, so I concluded the possible reason. I had no oscilloscope to aid in verifying.
I even stripped the damn thing down afterwards to see if I could spot anything but it all looked OK.
I had to make this provisional conclusion as a possible, I hate a lack of a conclusion but had no other choice on this one.
As you say, looking at images on Google will presumably 'sway' things in the direction of "how many left handers are in use". Hence, if most CUs in use were MK or Crabtree ('left handers') one would expect Googles images to major on those two brands.
However, despite the fact that you correctly quoted what I had written, that is not what I was talking about. I was talking about the number of brands which had main switches on left (regardless of how many of which brand were 'in use') - and I have suggested that such brands probably represent only a fairly small proportion of the brands available..
Yes, I recall that discussion, but I don't think that any of us had any good explanation (or even 'suggestion') as to how such switch behaviour (if present) could result in an RCD tripping.
Does anyone know, in general, whether (and, if so, which) any of the types of DP switches we generally use have a designed non-simultaneous making/breaking behaviour?
As clearly stated I didn't look at makes, only the handidness of each image and I felt it was close to 50:50. I won't repeat the search as experience tells me a different selection will result. for all I know there could have been 15 left and 18 right I saw.
For all I know there could have been 15 MK and 18 other makes or 15 other makes and 18 BG, none of which gives no relevant statistic as to makes, as such my
... yes, we sort-of got that far in our thinking 'back then'. If enough current flows through one side of the RCD to cause it to operate, after one side of the load has been disconnected, there would probably have to be some sort of (capacitive/inductive) coupling as part of the picture.
