Cabling for motorised valves
25 Nov 2006
London
Hello
Hopefully this is not one for the plumbing forum.
In the future I may add an indirect hot water cylinder and zones to my central heating using motorised valves so want to be sure the cabling is in place.
Given the layout of the pipework the valves would be at the branches and not the boiler. (I know they need to be accessible for maintenance or replacement.)
Should the cable that powers them just run separately back to a position near the boiler? To avoid any channeling up the walls I plan to have wireless thermostats in the zones..
Would be grateful for a steer on what cable to run and where! Thanks .
I have motorised valves in all rooms, all wireless, they are often called TRV's, but with electronic heads, they are motorised valves.
With gas boilers they modulate, i.e. turn up and down, not on and off, so the controls also need to turn up/down, not on/off, so an old fashion hard-wired motorised valve only turns on/off, so are not a good idea with a modern gas boiler.
If there is a large area of the home, as in my case a flat under the main house, which is often not used then maybe there is a case for the old fashion control, but in the main, things like S Plan are very last century.
I have put my tin hat on, waiting for the flack, as I am sure many don't agree with me.
Thanks ericmark. I wasn’t thinking of ‘smart’ TRVs on the rads themselves but a type of gate valve that sits on a branch pipe of the CH flow. So say the back of the house is cold, it would allow CH flow to that branch but be closed to the branch to the warm front of the house until the thermostat called for it.
Just looking online and I’m thinking 5 core heat resistant cable should run between the valves and a central point by the boiler that feeds directly into it?
Won’t be doing any of this myself but may as well run the cable while floorboards are up. Or as you say, that’s old fashioned and it can all be done wirelessly?
Today can all be done wireless. The likes of Drayton Wiser the TRV on each radiator is programmed, the idea is every room is independent.
The whole idea hinges around modern boilers gaining the latent heat from the flue gasses, to do this the return water needs to be cold enough, so the boiler is able to modulate, (turn down) if the return water is too warm. But this takes time, so all control needs to be analogue to give time for the boiler to adjust the output.
The boiler will reach a point when it can't turn down any move, at this point it will start a mark/space ratio, turning on and off, but as soon as the boiler switches off, using a programmer or on/off thermostat, it has to start again from scratch.
There are analogue thermostats, using protocols like OpenTherm, which can turn the boiler up/down, but not all boilers use the same protocol, so often it would need some form of converter.
But if only turning off/on maybe 4 times a day, not really a problem, so with say 9 TRV heads all sending signals to the control hub, the chance of none of them demanding heat is slim, so the boiler rarely turns off, just goes up/down in output.
The boiler starts at flat out output, as each TRV starts to close, the pressure raises, until the by-pass valves lifts, and hot water returns to the boiler. So reducing boiler output.
But for it to work, the lock shield valves need to be carefully set, as I said speed is important, Flat Battery TRV.jpg the electronic TRV gives one target and current temperatures, if the current exceeds the target then the lock shield valve is open too much. Using on/off control, we get a hysteresis Temp_variation_on_off.jpg using analogue control we get a smooth graph Temp_variation_OpenTherm.jpg it is easy enough to realise we don't want valves which simply turn on/off.
5 core flex for each valve, from the valve location to wherever the rest of the system will be located.
Wireless thermostat receivers (or wired thermostats) will also need to be connected, as will a thermostat for the hot water cylinder. 5 core flex can be used for those as well, although they probably won't need 5 cores it makes sense to use the same type as then you don't need to buy multiple types of flex, and it allows for other alterations in future.
Normally all of the items have their own flex/cable going to a central point, as does the boiler itself.
What setup do you currently have?
Thanks. Currently a 35kw combi boiler only but there’ll be 3 showers. I got a G3 plumber out to talk about adding an indirect cylinder, he thought the boiler would be up to it. I’m not so sure so I thought I’d lay the groundwork anyway.
I’ve extended the CH pipes and cold water inlet to where a cylinder would go (airing cupboard). There’s already a radial circuit back to the CU (nothing else on it).
… as will a thermostat for the hot water cylinder.
Thanks. Can that be wireless? The cylinder would be upstairs, the boiler downstairs. Currently the flow/return tees off to the airing cupboard before it runs to the upstairs rads. Where would the CH/HW valve be positioned? And is 0.75mm 5 core okay?
Ericmark - thanks for the detailed explanation but it’s way over my head! Bottom line is I’ve not seen any motorised trvs that complement traditional rads so am thinking old school. I’ve used them previously on a Vaillant system and they were so noisy - especially annoying when I was trying to get to sleep and they were whirring away! There are three floors and a lot of rads so I think it would be very costly.
It will be, it's already grossly oversized as it's been sized for instant hot water delivery.
Wireless cylinder thermostats do exist, but unvented cylinders require a hard wired hi-limit thermostat, so the whole lot might as well be wired as a cable will be needed even if the temperature sensing part of it is wireless.
Forgive my ignorance but I assume the cylinder thermostat is built in to the cylinder? So I run 5 core cable from the valve positions as well as the cylinder position, all back to the boiler position? And should the thermostat cable be 1mm not 0.75?
Does it need to be in conduit or are there any regs I need to be aware of? Some of the cable will pass under a floor that will be tiled so I don’t want to get it wrong. Thanks for your help.
As said, the boiler seems grossly oversized, my three-story house has a 20 kW boiler. Years ago I fitted wireless tank thermostats to my dad's house, but when I tried with this house, I could no longer find any for sale.
I see non-vented cylinders as a pain, last thing I want is to have the cylinders tested every year, I would always go for vented type, it is like the water tube boiler v fire tube boiler, there are advantages with both, but having the pressure in the hot coil seems a safer option to me.
But I have seen some great plans and systems, Torrent pipe example.PNG looking at it seemed the bees knees, until started to look at cost, £12k for central heating to me is OTT.
0.75mm is more than adequate, for all the wiring of a heating system. All systems have all the wiring, run to a central point. The 'central point', is usually in the airing cupboard, where the hot water cylinder is located, the pump, and at least one valve.
Modern boilers, expect the pump, to be directly controlled by the boiler, so a separate cable will be need from the boiler, to the 'central point', for that purpose, in addition to the cable which tells the boiler to run.
The cylinder thermostat is usually mounted on the side of the cylinder, tight against the copper, about 1/3 up from the base. An alternative to the bi-metal switching type thermostat, on more up-to-date systems, is a sensor which measures the actual temperature of the cylinder.
"I've extended the CH pipes to where a cylinder would go"
Obviously think about summer time (for example). You need boiler hot water to the cylinder when the heating is off.
The return can be combined with the CH return.
These days you also need a bypass valve, for when all the motorized valves shut off, so the boiling water can return to the boiler.
Pressurised cylinders are good, but you need to drain the expansion once a year, otherwise they fail and spring a leak.
You also need a copper "over flow" to outside, (lots of regulations about these alone, as it is hot water). But basically ideally exit house at a low level. It's connected to the pressure relief valves
Thanks for all the replies. I’m trying to keep up!
I see non-vented cylinders as a pain, last thing I want is to have the cylinders tested every year, I would always go for a vented type
I don’t fancy the idea of an annual call out either (or pressurised boiling water flying about!) but with vented, wouldn’t the water tank need to be higher than the top floor shower? That wouldn’t be possible, plus I’d have access issues having a tank in the eaves.
Sorry, could you explain please? I thought the cold feed went into the cylinder for heating up the hot water feeds to the showers etc? In the summer I thought the rads would be off but the boiler would still be keeping the CH flow and return circulating to the cylinder coil via a (3 port?) valve. Is that not how it works?
I read about that, then I read that my boiler has a bypass valve within it - are they two different things?
So if I run everything to the airing cupboard, I’ll need 5 core heat resistant cable running from the motorised valves, and the same between the boiler and the cylinder? Does it need to be in conduit?
Can all this run off the one 2.5mm radial circuit?
5 core certainly keeps your options open, but no need for heat-resistant, or conduit, unless there is a risk of mechanical damage.
