C U main cable SWA
8 Feb 2025
Due to distance from meter the cable supply is armoured swa how is this terminated aft c u entry point
EICR next week full price of c u with any remedials next week, he uses wylex mostly
Why?
Whatever he's put in the report can't be effectively challenged, he won't change anything, and petend is still going to have to pay.
He’s having a new cu installed I believe, so yes.
Always interesting what happens at the other end though.
Why?
Err, so you've forgotten the number of threads here (and in other forums) where the EICR claims lots of stuff must be done, but in fact it's a made up excuse for fleecing the customer - or at least, somewhere between that and reality. Not saying that's the case here, but there is certainly scope for challenging EICRs if they are "bad".
But in answer to the OP, SWA needs to be terminated using the proper gland, and properly connecting the wire armouring at each end. Connecting the SWA gland to earth/chassis can be done by scraping paint off to allow the gland to contact bare metal, or using a banjo to connect it to a wire tail, or using something like a Piranha nut - the "best" option varying with the installation. All that is down to the electrician doing the work - but it can be good to have some knowledge and be able to spot if it's being bodged.
That used to be the case, when EICRs had no teeth at all. However, if it's a rented property, then the legislation we now have brings that into question. The legislation requires the landlord to provide the tenant with a copy of any inspection report, and also triggers the requirement for any C1s or C2s to be remedied within 28 days - without any apparent mechanism for challenging/appealing against the EICR (hence the need for 'remedial action'), even if it is "bad".
As JohnW2 pointed out though, once issued the 28-day timer starts counting down.
Plus there is no formal process for "challenging" an EICR, no "appeal body", no oversight, no upper tier of reviewers. All a landlord can do is to refuse to pay, and then hope to show in any court case that the EICR was so deeply flawed and improperly done that not paying was reasonable. Time, legal fees, expert witness costs...
And all the while that timer is going tick, tick, tick.
I don't know how widespread this problem is. People tend to complain when things are wrong, and not report when they are right, so one can easily get a distorted view. You'd think that the various "trade bodies" for residential landlords could step up and help, e.g. maintaining a register of electricians known to be realistic in their codings. Maybe even, with the involvement of electrical engineering experts, produce their own "best practice guide", following which would not contravene the regulations but would prevent the "bad" codings.
FWIW the 28 day rule is so ill thought out. If the remedial work involves a partial rewire it could take a few months to organise
C1’s should be resolved within days
Just saying
We've been agreeing about that (together with major problems associated with the inspections and the absence of any challenge/appeal process) for the last 3 or 4 years.
However, unfortunately, 'the law id the law'.
