EICR next week full price of c u with any remedials next week, he uses wylex mostly
Is the CU made of metal?Due to distance from meter the cable supply is armoured swa how is this terminated aft c u entry point
Err, so you've forgotten the number of threads here (and in other forums) where the EICR claims lots of stuff must be done, but in fact it's a made up excuse for fleecing the customer - or at least, somewhere between that and reality. Not saying that's the case here, but there is certainly scope for challenging EICRs if they are "bad".Why?
Whatever he's put in the report can't be effectively challenged, he won't change anything, and petend is still going to have to pay.
That used to be the case, when EICRs had no teeth at all. However, if it's a rented property, then the legislation we now have brings that into question. The legislation requires the landlord to provide the tenant with a copy of any inspection report, and also triggers the requirement for any C1s or C2s to be remedied within 28 days - without any apparent mechanism for challenging/appealing against the EICR (hence the need for 'remedial action'), even if it is "bad".Err, so you've forgotten the number of threads here (and in other forums) where the EICR claims lots of stuff must be done, but in fact it's a made up excuse for fleecing the customer - or at least, somewhere between that and reality. Not saying that's the case here, but there is certainly scope for challenging EICRs if they are "bad".
We've been agreeing about that (together with major problems associated with the inspections and the absence of any challenge/appeal process) for the last 3 or 4 years.FWIW the 28 day rule is so ill thought out.
