So the millions of properties that have pendant lighting will get a low rated EPC. As will those that have any other types of light fitting with G9, G4, GU10 and all the other styles of replaceable lamps, and all because someone might go and buy some inefficient incandescent lamps that are obsolete and have been off the market for years.
I'm regretting that blinking paper already. Bill Morris, I thought would be good. I saw a sample in the shop, but when it's hung, you can see the repeated pattern and it does my eyes in something rotten.
That's a massive job filling the holes and IMO you will always be able to see where they were - are you good at plastering / filling - or have to pay someone to do it.
Replacing with new GU10s would be much cheaper. Replaceable bulbs.
But the issue with replaceable bulbs is that it will affect your EPC and will lower your score due to Part L
How is filling existing holes a massive job?
Cut some 76mm board match existing, batten, but scrim over it.
Wide filling blade/knife and tub ready mixed Gyproc lite or similar.
