Concealed joints again!
I'm inclined to agree. I know there are theoretical arguments about 'creep' of copper in conductors, particularly when terminals are subject to appreciable thermal cycling
I've heard of and suffered, tinned flex end's suffering solder creep, under the pressure of terminal screws, but never bare copper.
True, but at least in the case of your illustration of the latter, the 'tug test' ought to have revealed the problem at the time of initial installation.
It feels like I should agree wholeheartedly but I have known the issue and on my work, I can only think the limited space in 5A JB's and the shape of the bends made it not so and later disturbance, maybe at the time other work is being performed, found it - possibly no fault actually existed
I would add that, in practice, the copper conductors are usually so soft that a problem such as you illustrate probably doesn't often arise, since if one does up the screw 'pretty tightly', it will often/usually squash the larger conductor enough for both to be reasonably 'gripped'. Also, of course, by far the most common situation is for all conductors in a terminal to be the same size.
(y)
Fair enough. I've heard of it with both solder and bare copper, but, for what it's worth, can't say tat I've experienced any significant cases with either.
Tinned flex is a massive no no in loudspeaker cabinets screwed or sprung clips where the added vibration will turn those 'perfect' connexions to mush PDQ. Very different to untreated Cu
Interesting. I can certainly understand that with screwed connections, but shouldn't #sprung' ones avoid that problem?
Taken as written, that would seem to mean that, per regs, one could have an 'inaccessible' joint made with screwed terminals if those terminals were enclosed in something (maybe a 'traditional' JB?) filled with 'a compound' (such as 'magic gel").
Or silicone sealant? Decorator's caulk? Silly Putty? Plasticine?
Are there any standards to which the "compound" must conform?
Quite so.
Certainly none stated ... and, of course, if it meant "chemical compound", that would not exclude very much at all (only chemical elements) :-)
I must say that I'm very surprised that I (and seemingly everyone else here) has never 'noticed' this aspect of the regs before!
Any adverse effects like arcing etc will be dampened by the compound
They might be (although I'm personally not at all sure to what extent arcing in JBs is a significant issue!) - but, as morq has pointed out, it rather depends upon what the 'compound' actually is ;)
To name but one, water is 'a compound' :-)
Well you wouldn't use silicon sealant or caulk on bare copper or brass would you?
That rather depends upon whether it's one containing acetic acid, doesn't it? There are one designed for 'electrical use' around.
However, morq's point was obviously that the regs seem to be happy with any 'compound' :-)
